跳转到主内容
加入维修社区 - 创建账户
Removing Olympus FE-210 Motherboard
你所需要的
  1. Removing Olympus FE-210 Motherboard, Battery: 步骤 1 中的图像 1,2 Removing Olympus FE-210 Motherboard, Battery: 步骤 1 中的图像 2,2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Motherboard: 步骤 2 中的图像 1,2 Removing Olympus FE-210 Motherboard: 步骤 2 中的图像 2,2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Motherboard, Front Casing: 步骤 3 中的图像 1,3 Removing Olympus FE-210 Motherboard, Front Casing: 步骤 3 中的图像 2,3 Removing Olympus FE-210 Motherboard, Front Casing: 步骤 3 中的图像 3,3
    • Remove the seven screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Motherboard: 步骤 4 中的图像 1,3 Removing Olympus FE-210 Motherboard: 步骤 4 中的图像 2,3 Removing Olympus FE-210 Motherboard: 步骤 4 中的图像 3,3
    • Apply enough pressure at the three snappable places to pull the front case off.
    • These three places are located:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Removing Olympus FE-210 Motherboard, Rear Casing: 步骤 5 中的图像 1,1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Removing Olympus FE-210 Motherboard: 步骤 6 中的图像 1,3 Removing Olympus FE-210 Motherboard: 步骤 6 中的图像 2,3 Removing Olympus FE-210 Motherboard: 步骤 6 中的图像 3,3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Removing Olympus FE-210 Motherboard, LCD Screen: 步骤 7 中的图像 1,2 Removing Olympus FE-210 Motherboard, LCD Screen: 步骤 7 中的图像 2,2
    • Remove the two 2.7 mm screws using a #00 screwdriver.
    • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
  8. Removing Olympus FE-210 Motherboard: 步骤 8 中的图像 1,3 Removing Olympus FE-210 Motherboard: 步骤 8 中的图像 2,3 Removing Olympus FE-210 Motherboard: 步骤 8 中的图像 3,3
    • Using a spudger, lift the latch on the connector.
    • Remove the ribbon cord from its connector.
    • Remove the LCD from the rest of the camera.
  9. Removing Olympus FE-210 Motherboard, Motherboard: 步骤 9 中的图像 1,2 Removing Olympus FE-210 Motherboard, Motherboard: 步骤 9 中的图像 2,2
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
  10. Removing Olympus FE-210 Motherboard: 步骤 10 中的图像 1,2 Removing Olympus FE-210 Motherboard: 步骤 10 中的图像 2,2
    • Remove the seven 2.7 mm using a #00 screwdriver.
  11. Removing Olympus FE-210 Motherboard: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
  12. Removing Olympus FE-210 Motherboard: 步骤 12 中的图像 1,1
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
  13. Removing Olympus FE-210 Motherboard: 步骤 13 中的图像 1,2 Removing Olympus FE-210 Motherboard: 步骤 13 中的图像 2,2
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
  14. Removing Olympus FE-210 Motherboard: 步骤 14 中的图像 1,1
    • Remove the motherboard from the camera casing.
结论
Alex Wolff
于01/21/11注册
234 声望
撰写一个指南
团队
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G36
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 77
总计 4,472
