跳转到主内容
Removing Olympus FE-210 Front Casing
你所需要的
  1. Removing Olympus FE-210 Front Casing, Battery: 步骤 1 中的图像 1,2 Removing Olympus FE-210 Front Casing, Battery: 步骤 1 中的图像 2,2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Front Casing: 步骤 2 中的图像 1,2 Removing Olympus FE-210 Front Casing: 步骤 2 中的图像 2,2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Front Casing, Front Casing: 步骤 3 中的图像 1,3 Removing Olympus FE-210 Front Casing, Front Casing: 步骤 3 中的图像 2,3 Removing Olympus FE-210 Front Casing, Front Casing: 步骤 3 中的图像 3,3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Front Casing: 步骤 4 中的图像 1,3 Removing Olympus FE-210 Front Casing: 步骤 4 中的图像 2,3 Removing Olympus FE-210 Front Casing: 步骤 4 中的图像 3,3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
结论
Matt
于01/25/11注册
826 声望
创作了6篇指南
团队
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G36
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,744
