跳转到主内容
Removing Numerical Keypad
你所需要的
  1. Removing Numerical Keypad, Removing Numerical Keypad: 步骤 1 中的图像 1,1
    • You can do this with most keyboards. I had an older Dell keyboard model L100.
  2. Removing Numerical Keypad: 步骤 2 中的图像 1,1
    • Turn the keyboard over and you will see 15 screws. Remove them.
  3. Removing Numerical Keypad: 步骤 3 中的图像 1,1
    • Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
  4. Removing Numerical Keypad: 步骤 4 中的图像 1,1
    • Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
  5. Removing Numerical Keypad: 步骤 5 中的图像 1,1
    • On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
  6. Removing Numerical Keypad: 步骤 6 中的图像 1,1
    • Now mark the bottom part of the keyboard for another cut.
  7. Removing Numerical Keypad: 步骤 7 中的图像 1,1
    • Cut the bottom part of the keyboard too. Fold or remove the plastic PCB out of the way when cutting.
  8. Removing Numerical Keypad: 步骤 8 中的图像 1,1
    • Screw the PCB and the metal bar back on.
  9. Removing Numerical Keypad: 步骤 9 中的图像 1,1
    • Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard. Do not cut it because it will render the keyboard useless.
  10. Removing Numerical Keypad: 步骤 10 中的图像 1,1
    • Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
  11. Removing Numerical Keypad: 步骤 11 中的图像 1,1
    • Tape the key to the keyboad
  12. Removing Numerical Keypad: 步骤 12 中的图像 1,1
    • Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
结论
4等其他人完成本指南。
Stanko Vuleta
于06/16/11注册
242 声望
撰写一个指南
9指南评论
This is awesome !!
What kind of saw and sawblade are you using?
Fixer - 回复
Manual hacksaw is probably the best choice. Any power tool is liable to burn the plastic and produce fumes which you don't want to be inhaling.
Stanko Vuleta -
Can i do this to an aluminum extended keyboard usb apple?
appleuserfan - 回复
Judging by the position of the cable, the pcb is placed away from the numerical keypad, so I would guess you should be able to do it.
Stanko Vuleta -
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 20
过去 30 天: 94
总计 12,830
