跳转到主内容
Removing Nokia 6236i Sim Card
  1. Removing Nokia 6236i Sim Card, Disassembling Nokia 6236i Battery: 步骤 1 中的图像 1,2 Removing Nokia 6236i Sim Card, Disassembling Nokia 6236i Battery: 步骤 1 中的图像 2,2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Removing Nokia 6236i Sim Card: 步骤 2 中的图像 1,3 Removing Nokia 6236i Sim Card: 步骤 2 中的图像 2,3 Removing Nokia 6236i Sim Card: 步骤 2 中的图像 3,3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Removing Nokia 6236i Sim Card, Removing Nokia 6236i Sim Card: 步骤 3 中的图像 1,3 Removing Nokia 6236i Sim Card, Removing Nokia 6236i Sim Card: 步骤 3 中的图像 2,3 Removing Nokia 6236i Sim Card, Removing Nokia 6236i Sim Card: 步骤 3 中的图像 3,3
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
结论
Jesse Roach
于04/24/10注册
13 声望
撰写一个指南
团队
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G46
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,355
