跳转到主内容
简介
This will guide you through removing the sim card.
工具
没有特定工具。
配件
没有特定配件。
  1. Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
    • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  3. Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
    • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
    • The battery should lift out with minimal resistance.
  4. Once you have removed the battery, pull the tab on the metal sim card cover, and lift it up. The sim card is underneath and can now be removed. The sim card is underneath and can now be removed.
    • Once you have removed the battery, pull the tab on the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
结论
Jesse Roach
于2010年04月24日注册
13 信誉积分
撰写一个指南
团队
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G46
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 2,249
