跳转到主内容
Nokia 3100b Screen Replacement
你所需要的
  1. Nokia 3100b Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure your phone is turned off.
  2. Nokia 3100b Screen Replacement: 步骤 2 中的图像 1,1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Screen Replacement, SIM Card: 步骤 3 中的图像 1,1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Screen Replacement: 步骤 4 中的图像 1,1
    • Retrieve your SIM card.
  5. Nokia 3100b Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Separate the front cover from the main body of the phone.
  6. Nokia 3100b Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the six screws along the edges of the phone.
  7. Nokia 3100b Screen Replacement: 步骤 7 中的图像 1,1
    • Pull the screen assembly from the base of the phone.
  8. Nokia 3100b Screen Replacement: 步骤 8 中的图像 1,1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Nokia 3100b Screen Replacement: 步骤 9 中的图像 1,1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Nokia 3100b Screen Replacement: 步骤 10 中的图像 1,1
    • Gently push down on the screen to pop it off of the assembly.
  11. Nokia 3100b Screen Replacement: 步骤 11 中的图像 1,1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
结论
另外一个人完成了本指南。
Sterling Fuentes
于04/09/10注册
130 声望
创作了8篇指南
团队
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G64
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,763
