跳转到主内容
Removing Nokia 3100b Keypad
  1. Removing Nokia 3100b Keypad, Battery: 步骤 1 中的图像 1,1
    • Make sure your phone is turned off.
  2. Removing Nokia 3100b Keypad: 步骤 2 中的图像 1,1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Removing Nokia 3100b Keypad, Removing Nokia 3100b Keypad: 步骤 3 中的图像 1,1
    • Push the black tabs down and pull the colored half of the phone from the white half.
  4. Removing Nokia 3100b Keypad: 步骤 4 中的图像 1,1
    • The front part of the phone is now removed. Make sure nothing was damaged while removing the front cover.
  5. Removing Nokia 3100b Keypad: 步骤 5 中的图像 1,1
    • Remove the keypad membrane by pulling it from the front cover.
结论
Sterling Fuentes
于04/09/10注册
130 声望
创作了8篇指南
团队
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G64
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 887
