跳转到主内容
Removing Nishiki Aero II Front Wheel
你所需要的
  1. Removing Nishiki Aero II Front Wheel, Removing Road Bike Front Wheel: 步骤 1 中的图像 1,1
    • Turn the bike upside down.
  2. Removing Nishiki Aero II Front Wheel: 步骤 2 中的图像 1,1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Removing Nishiki Aero II Front Wheel: 步骤 3 中的图像 1,2 Removing Nishiki Aero II Front Wheel: 步骤 3 中的图像 2,2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Removing Nishiki Aero II Front Wheel: 步骤 4 中的图像 1,1
    • Follow the previous steps for the opposite side.
  5. Removing Nishiki Aero II Front Wheel: 步骤 5 中的图像 1,1
    • Lift the wheel up from the fork.
结论
Tobias Elder
于04/25/13注册
113 声望
创作了7篇指南
团队
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G53
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 1,141
