跳转到主内容
加入维修社区 - 创建账户
Removing Nikon Coolpix 4600 Front and Rear case
你所需要的
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: 步骤 1 中的图像 1,2 Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: 步骤 1 中的图像 2,2
    • Locate the six screws on the exterior of the camera. There will be two 3.3 mm screws on the bottom and two 5.25 mm screws either side.
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: 步骤 2 中的图像 1,2 Removing Nikon Coolpix 4600 Front and Rear case: 步骤 2 中的图像 2,2
    • Gently separate the front and back casing by prying the two sides open with your hands. DO NOT separate them fully, as it could damage internal components.
    • The front case is attached to internal components and cannot be removed independently
  3. Removing Nikon Coolpix 4600 Front and Rear case: 步骤 3 中的图像 1,1
    • Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
    • Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
    • Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
结论
Nathan Sperling
于05/08/12注册
119 声望
创作了4篇指南
团队
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G43
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 1,781
