跳转到主内容
Removing Minolta X-370 Lens Holder
你所需要的
  1. Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: 步骤 1 中的图像 1,2 Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: 步骤 1 中的图像 2,2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: 步骤 2 中的图像 1,1
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - 回复
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: 步骤 3 中的图像 1,2 Removing Minolta X-370 Lens Holder, Bottom Cover: 步骤 3 中的图像 2,2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: 步骤 4 中的图像 1,1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: 步骤 5 中的图像 1,1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: 步骤 6 中的图像 1,3 Removing Minolta X-370 Lens Holder, Lens Holder: 步骤 6 中的图像 2,3 Removing Minolta X-370 Lens Holder, Lens Holder: 步骤 6 中的图像 3,3
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
    The photo is wrong, the red dot should be facing north, instead of west.
    Laura Ceja - 回复
  7. Removing Minolta X-370 Lens Holder: 步骤 7 中的图像 1,3 Removing Minolta X-370 Lens Holder: 步骤 7 中的图像 2,3 Removing Minolta X-370 Lens Holder: 步骤 7 中的图像 3,3
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: 步骤 8 中的图像 1,2 Removing Minolta X-370 Lens Holder: 步骤 8 中的图像 2,2
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: 步骤 9 中的图像 1,3 Removing Minolta X-370 Lens Holder: 步骤 9 中的图像 2,3 Removing Minolta X-370 Lens Holder: 步骤 9 中的图像 3,3
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: 步骤 10 中的图像 1,2 Removing Minolta X-370 Lens Holder: 步骤 10 中的图像 2,2
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: 步骤 11 中的图像 1,2 Removing Minolta X-370 Lens Holder: 步骤 11 中的图像 2,2
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: 步骤 12 中的图像 1,3 Removing Minolta X-370 Lens Holder: 步骤 12 中的图像 2,3 Removing Minolta X-370 Lens Holder: 步骤 12 中的图像 3,3
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
结论
4等其他人完成本指南。
Nick
于04/19/11注册
525 声望
创作了4篇指南
团队
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G7
4 名成员
创作了8篇指南
一条评论
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 7,197
