跳转到主内容
Removing Minolta X-370 Lens Holder
你所需要的
  1. Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: 步骤 1 中的图像 1,2 Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: 步骤 1 中的图像 2,2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: 步骤 2 中的图像 1,1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: 步骤 3 中的图像 1,2 Removing Minolta X-370 Lens Holder, Bottom Cover: 步骤 3 中的图像 2,2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: 步骤 4 中的图像 1,1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: 步骤 5 中的图像 1,1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: 步骤 6 中的图像 1,3 Removing Minolta X-370 Lens Holder, Lens Holder: 步骤 6 中的图像 2,3 Removing Minolta X-370 Lens Holder, Lens Holder: 步骤 6 中的图像 3,3
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  7. Removing Minolta X-370 Lens Holder: 步骤 7 中的图像 1,3 Removing Minolta X-370 Lens Holder: 步骤 7 中的图像 2,3 Removing Minolta X-370 Lens Holder: 步骤 7 中的图像 3,3
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: 步骤 8 中的图像 1,2 Removing Minolta X-370 Lens Holder: 步骤 8 中的图像 2,2
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: 步骤 9 中的图像 1,3 Removing Minolta X-370 Lens Holder: 步骤 9 中的图像 2,3 Removing Minolta X-370 Lens Holder: 步骤 9 中的图像 3,3
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: 步骤 10 中的图像 1,2 Removing Minolta X-370 Lens Holder: 步骤 10 中的图像 2,2
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: 步骤 11 中的图像 1,2 Removing Minolta X-370 Lens Holder: 步骤 11 中的图像 2,2
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: 步骤 12 中的图像 1,3 Removing Minolta X-370 Lens Holder: 步骤 12 中的图像 2,3 Removing Minolta X-370 Lens Holder: 步骤 12 中的图像 3,3
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
结论
4等其他人完成本指南。
Nick
于04/19/11注册
525 声望
创作了4篇指南
团队
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G7
4 名成员
创作了8篇指南
一条评论
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 7,269
