跳转到主内容
Removing Minolta X-370 Film Winding Lever
你所需要的
  1. Removing Minolta X-370 Film Winding Lever, Film Winding Lever: 步骤 1 中的图像 1,2 Removing Minolta X-370 Film Winding Lever, Film Winding Lever: 步骤 1 中的图像 2,2
    • Lift up the winding lever and rotate it clockwise to open the back film compartment.
  2. Removing Minolta X-370 Film Winding Lever: 步骤 2 中的图像 1,2 Removing Minolta X-370 Film Winding Lever: 步骤 2 中的图像 2,2
    • Lift up the winding handle and remove one 3.85mm screw.
    • Remove the film winding handle.
  3. Removing Minolta X-370 Film Winding Lever: 步骤 3 中的图像 1,2 Removing Minolta X-370 Film Winding Lever: 步骤 3 中的图像 2,2
    • Pull the film winder down until it comes free.
    • Do not close the film compartment. The compartment will not open without the film winding lever installed properly.
    The film wonder handle does not slide back up in place. There is something blocking the way so it will not slide back up in place. What do I do now?
    Richard Hood - 回复
结论
2等其他人完成本指南。
Nick
于04/19/11注册
525 声望
创作了4篇指南
团队
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G7
4 名成员
创作了8篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 37
总计 12,467
