跳转到主内容
Magellan RoadMate 1200 Back Cover Replacement
你所需要的
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 1200 Back Cover Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: 步骤 4 中的图像 1,2 Magellan RoadMate 1200 Back Cover Replacement: 步骤 4 中的图像 2,2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
结论
2等其他人完成本指南。
Ross Light
于04/12/10注册
217 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,467
