跳转到主内容
Removing Lenovo Thinkpad T61p RAM
你所需要的
  1. Removing Lenovo Thinkpad T61p RAM, RAM: 步骤 1 中的图像 1,2 Removing Lenovo Thinkpad T61p RAM, RAM: 步骤 1 中的图像 2,2
    • Place the laptop on a fat surface with the underside facing up
    • Remove the 4 Philips head screws.
    • Turn the computer over and open the display
    • Grasping each side of the palm rest, gently lift it off and rotate toward the front of the laptop
    • The palm rest will be connected to the main board by a ribbon cable
  2. Removing Lenovo Thinkpad T61p RAM: 步骤 2 中的图像 1,1
    • Disconnect the touchpad ribbon cable
    • This step is recommended in the service manual however it is possible to remove the RAM without discoinnecting the touchpad cable
  3. Removing Lenovo Thinkpad T61p RAM: 步骤 3 中的图像 1,1
    • Locate the RAM modules
    • Gently press the metal tabs outwards to release the top RAM module and remove it from the laptop
    • With the top RAM module removed you can release the lower RAM module in the same manner.
结论
5等其他人完成本指南。
Glac1er
于05/25/13注册
180 声望
撰写一个指南
团队
Glac1er Glac1er 的会员
Community
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 10,085
