跳转到主内容
Removing HP Compaq dx2000MT Case Fan
你所需要的
  1. Removing HP Compaq dx2000MT Case Fan, Removing the HP Compaq dx2000MT Case Doors: 步骤 1 中的图像 1,1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Case Fan: 步骤 2 中的图像 1,2 Removing HP Compaq dx2000MT Case Fan: 步骤 2 中的图像 2,2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Case Fan: 步骤 3 中的图像 1,3 Removing HP Compaq dx2000MT Case Fan: 步骤 3 中的图像 2,3 Removing HP Compaq dx2000MT Case Fan: 步骤 3 中的图像 3,3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Case Fan: 步骤 4 中的图像 1,3 Removing HP Compaq dx2000MT Case Fan: 步骤 4 中的图像 2,3 Removing HP Compaq dx2000MT Case Fan: 步骤 4 中的图像 3,3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Case Fan, Case Fan: 步骤 5 中的图像 1,3 Removing HP Compaq dx2000MT Case Fan, Case Fan: 步骤 5 中的图像 2,3 Removing HP Compaq dx2000MT Case Fan, Case Fan: 步骤 5 中的图像 3,3
    • Remove the 3 prong power connector from the motherboard by pulling it outwards toward the side of the device.
  6. Removing HP Compaq dx2000MT Case Fan: 步骤 6 中的图像 1,3 Removing HP Compaq dx2000MT Case Fan: 步骤 6 中的图像 2,3 Removing HP Compaq dx2000MT Case Fan: 步骤 6 中的图像 3,3
    • Remove the 4 push fasteners from the case by:
    • Prying them outwards with a small flathead screwdriver and
    • Pulling them out with tweezers or plyers.
  7. Removing HP Compaq dx2000MT Case Fan: 步骤 7 中的图像 1,3 Removing HP Compaq dx2000MT Case Fan: 步骤 7 中的图像 2,3 Removing HP Compaq dx2000MT Case Fan: 步骤 7 中的图像 3,3
    • Remove the fan from the case by pulling it towards the front of the device.
结论
3等其他人完成本指南。
Logan Pace
于10/12/11注册
2,224 声望
创作了9篇指南
团队
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G16
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,662
