跳转到主内容
Removing Fender Frontman 15r Back panel
你所需要的
  1. Removing Fender Frontman 15r Back panel, Back panel: 步骤 1 中的图像 1,1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Removing Fender Frontman 15r Back panel: 步骤 2 中的图像 1,1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Removing Fender Frontman 15r Back panel: 步骤 3 中的图像 1,1
    • Once the top is separated, use your hand to remove the back panel from the unit.
结论
Greg Sawers
于09/27/12注册
85 声望
创作了3篇指南
团队
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G30
5 名成员
创作了7篇指南
一条评论
I need to know where to find a used circuit board for my Fender Frontman 15G. A circuit board from a Fender Frontman 15R will also work. Please help me.
sparkyman401 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 27
总计 6,648
