配件
无需配件。
  1. Turn over the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
    • Turn over the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
  2. Locate the large button on the top back of the device. Press this button at the top while making a firm grip on the battery cover. As the button is pressed, move the cover towards the bottom of the device.
    • Locate the large button on the top back of the device.
    • Press this button at the top while making a firm grip on the battery cover.
    • As the button is pressed, move the cover towards the bottom of the device.
    • The battery removal tab may pop up during the cover removal process.
  3. Holding the device, grab the tab with thumb and index figure. Pull down on the tab to move the battery block a few millimeters towards the bottom of the device to unlock the latch at the top. After the latch at the top is disengaged, pivot the battery away from the back and the battery will be free.
    • Holding the device, grab the tab with thumb and index figure.
    • Pull down on the tab to move the battery block a few millimeters towards the bottom of the device to unlock the latch at the top.
    • After the latch at the top is disengaged, pivot the battery away from the back and the battery will be free.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. locate the four hex screws on the bottom of the device. Use a T6 hex bit  from the iFixit precision screwdriver set to remove the four screws. Use a T6 hex bit  from the iFixit precision screwdriver set to remove the four screws.
    • locate the four hex screws on the bottom of the device.
    • Use a T6 hex bit from the iFixit precision screwdriver set to remove the four screws.
  6. To remove the next two T6 screws, locate the button at the top of the back of the device. Around the button, there is a cover that protects the two screws. To remove the cover insert a flathead screwdriver or thumb nail and lift up until cover is removed.
    • To remove the next two T6 screws, locate the button at the top of the back of the device.
    • Around the button, there is a cover that protects the two screws.
    • To remove the cover insert a flathead screwdriver or thumb nail and lift up until cover is removed.
  7. After removing the cover, use the T6 screwdriver and remove the screws. After removing the cover, use the T6 screwdriver and remove the screws. After removing the cover, use the T6 screwdriver and remove the screws.
    • After removing the cover, use the T6 screwdriver and remove the screws.
  8. With the 6 screws removed, the back cover can be removed revealing the backside of the motherboard (PCB Logic Board). Pull up on the back cover from the device. Locate the power button.
    • With the 6 screws removed, the back cover can be removed revealing the backside of the motherboard (PCB Logic Board).
    • Pull up on the back cover from the device.
    • Locate the power button.
  9. Remove the power button from the left. Locate the antenna extension connector on the right and remove the plastic piece. Locate the antenna extension connector on the right and remove the plastic piece.
    • Remove the power button from the left.
    • Locate the antenna extension connector on the right and remove the plastic piece.
  10. After removing the screws and two external pieces, the PCB Logic Board can be removed from the front piece. Simply pull up on the PCB Logic Board to remove. CAUTION: Be careful of the LCD screen and keypad as they are only connected via ribbon cables to the board. They will hang down as the PCB Logic Board is removed.
    • After removing the screws and two external pieces, the PCB Logic Board can be removed from the front piece.
    • Simply pull up on the PCB Logic Board to remove.
    • CAUTION: Be careful of the LCD screen and keypad as they are only connected via ribbon cables to the board. They will hang down as the PCB Logic Board is removed.
结论
另外一个人完成了本指南。
Scott Byer
于2012年03月09日注册
61 信誉积分
创作了5篇指南
团队
Clemson, Team 1-2, Benson Spring 2012 Clemson, Team 1-2, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G2
3 名成员
创作了9篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 2,147
