跳转到主内容
Removing Dell Inspiron 530 Processor
你所需要的
  1. Removing Dell Inspiron 530 Processor, Side Panel: 步骤 1 中的图像 1,1
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Removing Dell Inspiron 530 Processor: 步骤 2 中的图像 1,1
    • Slide the side panel towards the back and remove.
  3. Removing Dell Inspiron 530 Processor, Removing Processor: 步骤 3 中的图像 1,1
    • Locate the processor's heat sink and fan.
  4. Removing Dell Inspiron 530 Processor: 步骤 4 中的图像 1,1
    • Remove the fan's power cable from the motherboard.
  5. Removing Dell Inspiron 530 Processor: 步骤 5 中的图像 1,1
    • Locate and unscrew the four Phillips #0 screws at the corners of the fan.
    • The screws will not come out completely.
  6. Removing Dell Inspiron 530 Processor: 步骤 6 中的图像 1,1
    • Remove the fan and heat sink.
  7. Removing Dell Inspiron 530 Processor: 步骤 7 中的图像 1,1
    • Gently press down and release the silver lever.
  8. Removing Dell Inspiron 530 Processor: 步骤 8 中的图像 1,1
    • Open the metal casing over the processor.
  9. Removing Dell Inspiron 530 Processor: 步骤 9 中的图像 1,1
    • Gently lift up the processor, holding by the edges only.
结论
Note: For reassembly on step seven, make sure the corner of the processor with the gold triangle is pointing towards the release lever.
14等其他人完成本指南。
James Aldag
于10/20/11注册
402 声望
创作了3篇指南
团队
Cal Poly, Team 6-8, Regan Fall 2011 Cal Poly, Team 6-8, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G8
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 35
总计 9,078
