跳转到主内容
简介
The purpose of this guide is to demonstrate how to locate and remove the 1150 Wireless MiniPCI Card.
配件
没有特定配件。
  1. Turn the laptop upside down and  locate the panel labeled C. Unscrew the single screw holding the cover in place. lift up the cover and remove it to exposed the Wireless MiniPCI Card.
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • lift up the cover and remove it to exposed the Wireless MiniPCI Card.
  2. Using a plastic spudger or similar, gently pry the grey and black wires off. The grey and black wires are the antenna wires so be careful not to damage them
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
结论
另外一个人完成了本指南。
Teja
于2010年04月27日注册
98 信誉积分
创作了3篇指南
团队
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G2
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 2
过去的30天: 10
总计 5,541
