跳转到主内容
Removing Dell Inspiron 1150 RAM
你所需要的
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: 步骤 1 中的图像 1,1
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: 步骤 2 中的图像 1,2 Removing Dell Inspiron 1150 RAM: 步骤 2 中的图像 2,2
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: 步骤 3 中的图像 1,3 Removing Dell Inspiron 1150 RAM: 步骤 3 中的图像 2,3 Removing Dell Inspiron 1150 RAM: 步骤 3 中的图像 3,3
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
结论
Christopher
于04/27/10注册
8 声望
撰写一个指南
团队
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 17
总计 5,837
