跳转到主内容
Removing Dell Inspiron 1150 Optical drive
你所需要的
  1. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 1,3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 2,3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 3,3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: 步骤 2 中的图像 1,2 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: 步骤 2 中的图像 2,2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Removing Dell Inspiron 1150 Optical drive: 步骤 3 中的图像 1,2 Removing Dell Inspiron 1150 Optical drive: 步骤 3 中的图像 2,2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 步骤 4 中的图像 1,3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 步骤 4 中的图像 2,3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 步骤 4 中的图像 3,3
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
结论
Daniel
于04/25/10注册
87 声望
创作了2篇指南
团队
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G2
4 名成员
创作了9篇指南
一条评论
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 5,871
