跳转到主内容
Removing Dell Inspiron 1150 Mini Wireless PCI Card
你所需要的
  1. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: 步骤 1 中的图像 1,3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: 步骤 1 中的图像 2,3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: 步骤 1 中的图像 3,3
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Wireless MiniPCI Card.
  2. Removing Dell Inspiron 1150 Mini Wireless PCI Card: 步骤 2 中的图像 1,2 Removing Dell Inspiron 1150 Mini Wireless PCI Card: 步骤 2 中的图像 2,2
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Removing Dell Inspiron 1150 Mini Wireless PCI Card: 步骤 3 中的图像 1,1
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
结论
另外一个人完成了本指南。
Teja
于04/27/10注册
98 声望
创作了3篇指南
团队
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 5,903
