跳转到主内容
Removing Dell Inspiron 1150 LCD from Display Assembly
你所需要的
  1. Removing Dell Inspiron 1150 LCD from Display Assembly, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 1,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 2,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 3,3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 LCD from Display Assembly, Hard Drive: 步骤 2 中的图像 1,2 Removing Dell Inspiron 1150 LCD from Display Assembly, Hard Drive: 步骤 2 中的图像 2,2
    • Place laptop upside down on a clean flat surface.
    • Remove 2ea M2.5 x 5 mm screws.
    • Pull the HDD from main body of the laptop.
  3. Removing Dell Inspiron 1150 LCD from Display Assembly, Optical Drive (Based on Dell Service Manual): 步骤 3 中的图像 1,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Optical Drive (Based on Dell Service Manual): 步骤 3 中的图像 2,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Optical Drive (Based on Dell Service Manual): 步骤 3 中的图像 3,3
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
  4. Removing Dell Inspiron 1150 LCD from Display Assembly, Keyboard: 步骤 4 中的图像 1,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Keyboard: 步骤 4 中的图像 2,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Keyboard: 步骤 4 中的图像 3,3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  5. Removing Dell Inspiron 1150 LCD from Display Assembly: 步骤 5 中的图像 1,3 Removing Dell Inspiron 1150 LCD from Display Assembly: 步骤 5 中的图像 2,3 Removing Dell Inspiron 1150 LCD from Display Assembly: 步骤 5 中的图像 3,3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
  6. Removing Dell Inspiron 1150 LCD from Display Assembly, Display Assembly: 步骤 6 中的图像 1,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Display Assembly: 步骤 6 中的图像 2,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Display Assembly: 步骤 6 中的图像 3,3
    • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
    • Remove the EMI shield to expose the LCD ribbon cable
    • Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
  7. Removing Dell Inspiron 1150 LCD from Display Assembly: 步骤 7 中的图像 1,3 Removing Dell Inspiron 1150 LCD from Display Assembly: 步骤 7 中的图像 2,3 Removing Dell Inspiron 1150 LCD from Display Assembly: 步骤 7 中的图像 3,3
    • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
    • Remove 2e M2.5 x 5mm screws from each hinge bracket
    • The Display Assembly can now be lifted free of the laptop body
  8. Removing Dell Inspiron 1150 LCD from Display Assembly, Removing LCD from Display Assembly: 步骤 8 中的图像 1,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Removing LCD from Display Assembly: 步骤 8 中的图像 2,3 Removing Dell Inspiron 1150 LCD from Display Assembly, Removing LCD from Display Assembly: 步骤 8 中的图像 3,3
    • Remove the 2 screw covers and 3 rubber bumpers to reveal 5ea M2.5 x 5mm Philips screws
    • Remove the 5 screws and gently lift off the screen bezel (surround) to reveal the LCD panel and mounting screws which are along each side of the LCD
    • Remove 8ea M2 x 3mm (4 screws along each side)
    • The LCD display can now be removed from the top cover of the laptop
    • The inverter PCB is located on the bottom edge of the LCD display panel and is easily removed
结论
2等其他人完成本指南。
Richdave
于04/09/10注册
32,287 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 858
