简介
This is a step-by-step guide to remove the outermost shell and innermost shell to get inside the device for further repairs.
WARNING: In this guide, you will be cutting the warranty seals. Once warranty seals are broken, you may no longer return the product.
TIPS:
- Be sure to check the screwdriver heads before performing this task; otherwise, screws may become damaged.
- Use an ice cube tray or egg carton, place each screw in its own cup to organize the screws.
你所需要的
Flip the Braven BRV-X upside down so you are facing the bottom side.
With the H1.5 Head Screwdriver, unscrew the four screws.
Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
Gently remove the outer casing, which should reveal the inner shell.
另外一个人完成了本指南。
