跳转到主内容
Removing Braven BRV-X Bottom Outer Casing
你所需要的
  1. Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: 步骤 1 中的图像 1,3 Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: 步骤 1 中的图像 2,3 Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: 步骤 1 中的图像 3,3
    • Flip the Braven BRV-X upside down so you are facing the bottom side.
    • With the H1.5 Head Screwdriver, unscrew the four screws.
    • All screws on this device can be stripped easily. Hold your screwdriver with the thumb on top and swivel with the opposite hand's thumb and index finger.
    • Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
    • Gently remove the outer casing, which should reveal the inner shell.
  2. Removing Braven BRV-X Bottom Outer Casing: 步骤 2 中的图像 1,2 Removing Braven BRV-X Bottom Outer Casing: 步骤 2 中的图像 2,2
    • With a Jimmy, cut the two warranty seals on either side.
    • You may also use a tech knife instead of a Jimmy.
    • WARNING: Once warranty seals are broken, you may no longer return the product.
    • Next, remove the 18 screws with a #00 Phillips screwdriver.
  3. Removing Braven BRV-X Bottom Outer Casing: 步骤 3 中的图像 1,2 Removing Braven BRV-X Bottom Outer Casing: 步骤 3 中的图像 2,2
    • Using two plastic opening tools, slide under the cover and slowly lift.
    • There is glue nearly all around the inner shell, so strength will be necessary. When both tools are inserted, you can slide out along the edges.
结论
另外一个人完成了本指南。
团队
Texas Tech, Team 19-4, Rauch Fall 2015 Texas Tech, Team 19-4, Rauch Fall 2015 的会员
TTU-RAUCH-F15S19G4
4 名成员
创作了2篇指南
一条评论
How do you remove the charging port
Neto - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,587
