跳转到主内容
Removing Bowers and Wilkins Zeppelin Air Dock Arm
你所需要的
  1. Removing Bowers and Wilkins Zeppelin Air Dock Arm, Dock Arm: 步骤 1 中的图像 1,1
    • Place the Zeppelin upside down. You can use the included packaging parts for this.
  2. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 2 中的图像 1,3 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 2 中的图像 2,3 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 2 中的图像 3,3
    • Remove the rubber on the bottom. Slowly pull it up from one side. It's attached with glue.
  3. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 3 中的图像 1,2 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 3 中的图像 2,2
    • Remove the six screws that attach the dock arm to the Zeppelin.
    • Lift up the dock arm.
  4. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 4 中的图像 1,3 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 4 中的图像 2,3 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 4 中的图像 3,3
    • Unplug the frontmost connector.
    • You might have to use a knife or the flat end of a spudge to push the tab.
  5. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 5 中的图像 1,2 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 5 中的图像 2,2
    • Unplug the other connector. I just pulled until it unplugged.
    • Remove the dock arm.
  6. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 6 中的图像 1,1
    • Find something to cover up the hole. This prevents the glue from sticking to internal parts. I used the cover of a plastic ice box.
  7. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 7 中的图像 1,1
    • Replace the screws. (Or store them somewhere safe.)
  8. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 8 中的图像 1,1
    • Use tape to close the hole that was once covered by the dock arm. This prevents dust from getting into your Zeppelin. (Black tape might work better, although you almost won't see the tape at all.)
  9. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 9 中的图像 1,2 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 9 中的图像 2,2
    • Attach the rubber bottom again. Use the screw holes (for the wall mount) for perfect alignment.
    • Make sure the glue attaches to the tape. Otherwise dust might get through the gap.
  10. Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 10 中的图像 1,2 Removing Bowers and Wilkins Zeppelin Air Dock Arm: 步骤 10 中的图像 2,2
    • Enjoy your now even better Zeppelin, and store the dock arm somewhere safe!
终点
17等其他人完成本指南。
Some Guy
于01/16/11注册
741 声望
撰写一个指南
30条评论
Caution Loud volume is distorted. I tried this with hard plastic and when bass notes were at 1/2 or louder volume there was a loud rattling sound. Tried again with a cut up black sock taped and cut in place, still distorted but barely at normal volumes. Good thing nothing is permanent as going back it sounds fine. Test a song with punchy bass loud before and after, I used Too Late by Ariane Moffatt and Counting by Autre Ne Veut. I wouldn't have noticed with the black fabric if I wouldn't have been listening for it. Probably not meant to be a semi-open speaker. B&W could have saved me some time and stated the reason why, not just the 'void warranty' I read everywhere that has ended anyway.
stoicalken - 回复
Any one have a docking arm assem. they want to sell. I'll pay good money for a working one. Mine got damaged. i12gocruzin2@yahoo.com Tim
i12gocruzin2 - 回复
As an appendix to this, you can also pull the dock arm apart, remove the wires, remove the dock connector and retain the led wire, put the LED wire inside the base, cut the dock arm at the base and then screw it back together. Fill in the cable holes with hot glue, and then reattach the base and you get a dock-less zeppelin with a glowing hole in the base with the ability to blast it at full volume with no distortion!
15 mins with a screwdriver and a hot glue gun and a hobby saw.
Jarrah Nelson - 回复
Jarrah Nelson, Can you send me pic of the result? or possibly of the process? I just saw Zeppelin Wireless and love it w/o Docking arm which I don't use.
mashyboy@gmail.com
thanks
Nick name -
Hey guys,
I'll just leave this here:
http://i.imgur.com/9kSGZJ9.jpg
Cheers!
Eric - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 43
过去 30 天: 189
总计 55,374
