当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
Be careful, make sure you don't lose the screws.
Carefully squeeze the top right corner of the camera and pry off the external cover.
If you hear a "cracking" sound. This is normal.
Continue to pull the external cover and it will come off cleanly.
Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
