跳转到主内容
加入维修社区 - 创建账户
Removing Aftermarket Vehicle Window Tinting
你所需要的
  1. Removing Aftermarket Vehicle Window Tinting, Before Photos: 步骤 1 中的图像 1,3 Removing Aftermarket Vehicle Window Tinting, Before Photos: 步骤 1 中的图像 2,3 Removing Aftermarket Vehicle Window Tinting, Before Photos: 步骤 1 中的图像 3,3
    • This is what your window will look like before.
    • And the third photo shows what it will look like after!
    询问修复机器人
    添加评论
  2. Removing Aftermarket Vehicle Window Tinting: 步骤 2 中的图像 1,2 Removing Aftermarket Vehicle Window Tinting: 步骤 2 中的图像 2,2
    • Roll down the window about 1/4 of the way so you can start to remove the tint from the top.
    询问修复机器人
    添加评论
  3. Removing Aftermarket Vehicle Window Tinting: 步骤 3 中的图像 1,3 Removing Aftermarket Vehicle Window Tinting: 步骤 3 中的图像 2,3 Removing Aftermarket Vehicle Window Tinting: 步骤 3 中的图像 3,3
    • Heat the area with a heat gun at the window's edge.
    • Start by using the low setting on the heat gun to gradually heat the surface. After the area has warmed up, you can switch to high heat to make it easier to remove the film.
    • Use the razor blade to peel a small area of the tint film up.
    询问修复机器人
    添加评论
  4. Removing Aftermarket Vehicle Window Tinting: 步骤 4 中的图像 1,2 Removing Aftermarket Vehicle Window Tinting: 步骤 4 中的图像 2,2
    • Once you've peeled enough with the razor blade to use your fingers, heat the area, then peel with your fingers.
    • Don't pull with your fingers and heat the area with the gun simultaneously. You'll burn yourself.
    • Heat the film angling the heat gun up. This will ensure that the film will not rip easily.
    询问修复机器人
    添加评论
  5. Removing Aftermarket Vehicle Window Tinting: 步骤 5 中的图像 1,1
    • When you've pulled enough film off so that you don't burn your fingers while simultaneously pulling, use a back-and-forth motion with the heat gun along the area where the film is still on the window while pulling on the film. (See next step)
    询问修复机器人
    添加评论
    • How to heat the area with the heat gun.
    询问修复机器人
    添加评论
  6. Removing Aftermarket Vehicle Window Tinting: 步骤 7 中的图像 1,2 Removing Aftermarket Vehicle Window Tinting: 步骤 7 中的图像 2,2
    • Once you have removed the film from the top of the window, you can roll up the window.
    • Continue doing a back-and-forth motion and pulling on the film until all of the film comes off.
    • If the film rips, no worries. Just continue. You can heat up those sections and remove them later.
    询问修复机器人
    添加评论
  7. Removing Aftermarket Vehicle Window Tinting: 步骤 8 中的图像 1,2 Removing Aftermarket Vehicle Window Tinting: 步骤 8 中的图像 2,2
    • Once you have removed all of the film, spray the window with glass cleaner and clean the window with either a rag or paper towel.
    询问修复机器人
    添加评论
  8. Removing Aftermarket Vehicle Window Tinting: 步骤 9 中的图像 1,2 Removing Aftermarket Vehicle Window Tinting: 步骤 9 中的图像 2,2
    • For areas where some residue is still on the window, spray the area with glass cleaner and use the razor blade to scrape the area to remove the residue.
    • For really tough residue, use Goo Gone in lieu of glass cleaner.
    询问修复机器人
    添加评论
  9. Removing Aftermarket Vehicle Window Tinting: 步骤 10 中的图像 1,2 Removing Aftermarket Vehicle Window Tinting: 步骤 10 中的图像 2,2
    • First photo: Before
    • Second photo: After
    询问修复机器人
    添加评论
  10. Removing Aftermarket Vehicle Window Tinting, Before and After: 步骤 11 中的图像 1,2 Removing Aftermarket Vehicle Window Tinting, Before and After: 步骤 11 中的图像 2,2
    询问修复机器人
    添加评论
结论
You are finished! Repeat the steps in this guide for every window you wish to remove the tinting.
取消:我没有完成这个指南。
另外一个人完成了本指南。
S.I. Dalton
于09/05/24注册
1,728 声望
创作了4篇指南
团队
Apple fan boys Apple fan boys 的会员
Community
57 名成员
创作了66篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 46
总计 771
