简介
There are a few reasons to want to take out your backseat:
  • Clean under it.
  • Put in a new seat.
  • To reach the rear speakers.
And this is a short and easy guide on how to remove the seat. Anyone can do it.
  1. Underneath the back seat on both sides will be either a tab or a lever (In mine, it has tabs)
    • Underneath the back seat on both sides will be either a tab or a lever (In mine, it has tabs)
  2. Pull/lift the tab/lever on each side to release the seat.
    • Pull/lift the tab/lever on each side to release the seat.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Lift up and remove the seat.
    • Lift up and remove the seat.
  5. Clean the seat or do whatever it is you wish to do. Clean the seat or do whatever it is you wish to do.
    • Clean the seat or do whatever it is you wish to do.
  6. Put the seat back on. As shown in the first image, be sure to put the seat belt and buckles through the slit on the seat. Otherwise, you will be without seat belts in the back. As shown in the second image is a hook that goes into the base of the backseat.
    • Put the seat back on.
      • As shown in the first image, be sure to put the seat belt and buckles through the slit on the seat. Otherwise, you will be without seat belts in the back.
      • As shown in the second image is a hook that goes into the base of the backseat.
      • The third image is of the tab that the hook on the seat goes into.
    • When you line up the hooks and tabs, push down hard. You will hear a click when the hooks are fitted into the tabs.
    • And there, your seat has been taken out and put back in! Good job!
结论
Your seat has now been taken out and put back in. Not hard, eh?
4等其他人完成本指南。
Scratchitory
于2013年04月25日注册
917 信誉积分
创作了3篇指南
Will back seats out of a 2004 or 5 grand Prix gt fit in 2003 SS Monte Carlo. Help please
Perry monahan - 回复
浏览统计数据:
过去的24小时: 3
过去的7天: 19
过去的30天: 69
总计 7,027
