跳转到主内容
Removing 1994-2001 Acura Integra Center Console
你所需要的
  1. Removing 1994-2001 Acura Integra Center Console, Center Console: 步骤 1 中的图像 1,2 Removing 1994-2001 Acura Integra Center Console, Center Console: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws at the very rear of the center console near the floor.
  2. Removing 1994-2001 Acura Integra Center Console: 步骤 2 中的图像 1,2 Removing 1994-2001 Acura Integra Center Console: 步骤 2 中的图像 2,2
    • Insert a small flathead screwdriver into the notch at the driver's side rear corner of the screw cover directly below the parking brake lever and pry it off.
    • Remove the two Phillips screws that were underneath the screw cover.
  3. Removing 1994-2001 Acura Integra Center Console: 步骤 3 中的图像 1,2 Removing 1994-2001 Acura Integra Center Console: 步骤 3 中的图像 2,2
    • Grab the bottom of the rear portion of the console and lift up and away from the front of the car.
    • Remove the rear portion of the center console.
  4. Removing 1994-2001 Acura Integra Center Console: 步骤 4 中的图像 1,2 Removing 1994-2001 Acura Integra Center Console: 步骤 4 中的图像 2,2
    • Pull the ash tray out from the center console until it stops.
    • Push down on the metal plate at the top of the ash tray and continue to pull the tray out until it is completely removed.
  5. Removing 1994-2001 Acura Integra Center Console: 步骤 5 中的图像 1,3 Removing 1994-2001 Acura Integra Center Console: 步骤 5 中的图像 2,3 Removing 1994-2001 Acura Integra Center Console: 步骤 5 中的图像 3,3
    • Remove two Phillips screws from behind the ash tray.
    • Remove the lower portion of the console that contains the cigarette lighter from the rest of the center console.
    • Disconnect the electrical connector for the cigarette lighter by first depressing the tab on top, and then pulling directly out of the socket.
  6. Removing 1994-2001 Acura Integra Center Console: 步骤 6 中的图像 1,3 Removing 1994-2001 Acura Integra Center Console: 步骤 6 中的图像 2,3 Removing 1994-2001 Acura Integra Center Console: 步骤 6 中的图像 3,3
    • Remove four Phillips screws that hold the side pieces of the front portion of the console in place.
    • Two below the radio pocket.
    • Two on the faces of the side pieces, one on either side.
  7. Removing 1994-2001 Acura Integra Center Console: 步骤 7 中的图像 1,2 Removing 1994-2001 Acura Integra Center Console: 步骤 7 中的图像 2,2
    • Remove the shift knob by unscrewing it counter-clockwise.
    • Lift the front portion of the center console up and away from the front of the car.
    • It may be necessary to pull the emergency brake handle up further to create enough room to remove the front portion of the center console.
结论
8等其他人完成本指南。
David Hodson
于04/13/10注册
150,455 声望
创作了127篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 19,126
