跳转到主内容
Removing 1985-1988 Volvo 740 Throttle Body
你所需要的
  1. Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: 步骤 1 中的图像 1,2 Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: 步骤 1 中的图像 2,2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Removing 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: 步骤 2 中的图像 1,1
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 3 中的图像 1,1
    • Locate throttle linkage cable assembly.
  4. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 4 中的图像 1,2 Removing 1985-1988 Volvo 740 Throttle Body: 步骤 4 中的图像 2,2
    • Twist the assembly clockwise.
  5. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 5 中的图像 1,1
    • Slide both slackened cables off assembly’s guides.
  6. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 6 中的图像 1,2 Removing 1985-1988 Volvo 740 Throttle Body: 步骤 6 中的图像 2,2
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 7 中的图像 1,1
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 8 中的图像 1,1
    • Remove the intake tube from the throttle body.
  9. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 9 中的图像 1,1
    • Locate wiring clip on the underside of the throttle body.
  10. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 10 中的图像 1,2 Removing 1985-1988 Volvo 740 Throttle Body: 步骤 10 中的图像 2,2
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 11 中的图像 1,3 Removing 1985-1988 Volvo 740 Throttle Body: 步骤 11 中的图像 2,3 Removing 1985-1988 Volvo 740 Throttle Body: 步骤 11 中的图像 3,3
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 12 中的图像 1,3 Removing 1985-1988 Volvo 740 Throttle Body: 步骤 12 中的图像 2,3 Removing 1985-1988 Volvo 740 Throttle Body: 步骤 12 中的图像 3,3
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Removing 1985-1988 Volvo 740 Throttle Body: 步骤 13 中的图像 1,1
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
结论
另外一个人完成了本指南。
Raymond
于10/11/10注册
76 声望
创作了2篇指南
团队
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G28
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 4,628
