本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide shows how to separate the GameCube's optical drive assembly from the motherboard.
你所需要的
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
Do not detach the red and black cooling fan wire from the main unit.(red wire)
即将完成!
结论
