跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Remove Nintendo GameCube Optical Drive Assembly
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: 步骤 1 中的图像 1,3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: 步骤 1 中的图像 2,3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: 步骤 1 中的图像 3,3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Remove Nintendo GameCube Optical Drive Assembly: 步骤 2 中的图像 1,3 Remove Nintendo GameCube Optical Drive Assembly: 步骤 2 中的图像 2,3 Remove Nintendo GameCube Optical Drive Assembly: 步骤 2 中的图像 3,3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Remove Nintendo GameCube Optical Drive Assembly, Optical Drive Assembly: 步骤 3 中的图像 1,2 Remove Nintendo GameCube Optical Drive Assembly, Optical Drive Assembly: 步骤 3 中的图像 2,2
    • The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit.(red wire)
  4. Remove Nintendo GameCube Optical Drive Assembly: 步骤 4 中的图像 1,2 Remove Nintendo GameCube Optical Drive Assembly: 步骤 4 中的图像 2,2
    • Remove the four (4) Phillips #1 screws retaining the ground springs (outlined in teal).
    • Carefully remove the ground springs from the main unit as shown in the second photograph.
  5. Remove Nintendo GameCube Optical Drive Assembly: 步骤 5 中的图像 1,2 Remove Nintendo GameCube Optical Drive Assembly: 步骤 5 中的图像 2,2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
  6. Remove Nintendo GameCube Optical Drive Assembly: 步骤 6 中的图像 1,3 Remove Nintendo GameCube Optical Drive Assembly: 步骤 6 中的图像 2,3 Remove Nintendo GameCube Optical Drive Assembly: 步骤 6 中的图像 3,3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached (picture 3).
结论
dcarlin
于11/05/09注册
301 声望
创作了4篇指南
团队
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G2
4 名成员
创作了45篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 4,390
