跳转到主内容
Remove IBM WorkPad c3 Battery
你所需要的
  1. Remove IBM WorkPad c3 Battery, Back Case: 步骤 1 中的图像 1,2 Remove IBM WorkPad c3 Battery, Back Case: 步骤 1 中的图像 2,2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Remove IBM WorkPad c3 Battery: 步骤 2 中的图像 1,1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Remove IBM WorkPad c3 Battery: 步骤 3 中的图像 1,2 Remove IBM WorkPad c3 Battery: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  4. Remove IBM WorkPad c3 Battery, Battery: 步骤 4 中的图像 1,1
    • Remove the yellow tape that is covering the battery connector
  5. Remove IBM WorkPad c3 Battery: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the tweezers, carefully disconnect the battery cable from the port
  6. Remove IBM WorkPad c3 Battery: 步骤 6 中的图像 1,2 Remove IBM WorkPad c3 Battery: 步骤 6 中的图像 2,2
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G35
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 29
总计 4,580
