跳转到主内容
加入维修社区 - 创建账户
Remove Dislodged Plug Parts
你所需要的
  1. Remove Dislodged Plug Parts, Remove Left Ear Cushion: 步骤 1 中的图像 1,2 Remove Dislodged Plug Parts, Remove Left Ear Cushion: 步骤 1 中的图像 2,2
    • Place the headphones down with ear cushions facing you
    • Cushions are held in by small tabs along the perimeter. Remove by hand
  2. Remove Dislodged Plug Parts, Remove Left Driver Pad: 步骤 2 中的图像 1,2 Remove Dislodged Plug Parts, Remove Left Driver Pad: 步骤 2 中的图像 2,2
    • Pad is held in by two pieces of double-sided tape. You only need to peel back the left piece, as shown
    • Be careful to avoid tearing the pad
  3. Remove Dislodged Plug Parts, Remove Left Backplate: 步骤 3 中的图像 1,2 Remove Dislodged Plug Parts, Remove Left Backplate: 步骤 3 中的图像 2,2
    • First, remove the two small philips screws securing the backplate to the body
    • Turn the headphones over and carefully wiggle the backplate away from the body. Use soft plastic tools if necessary to avoid scratching the plate
  4. Remove Dislodged Plug Parts, Remove Plug Circuit Board: 步骤 4 中的图像 1,2 Remove Dislodged Plug Parts, Remove Plug Circuit Board: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the two small, shorter philips screws securing the board to the body
    • The board is now held in by vinyl tape (black) and two ribbon cables
    • If you are just removing broken plug pieces, do not disconnect these ribbon cables - be careful not to damage them! Instead, simply lift the board enough to poke tweezers or similar through the plug to dislodge broken bits
    • If replacing the plug, disconnect the ribbon cables (one is soldered in place) from the circuit board and replace the board
结论
Reassembly is the reverse of disassembly - no surprises. Optionally, replace your ear cushions, pads, or double sided tape in the process.
6等其他人完成本指南。
Michael Pangburn
于12/31/20注册
280 声望
撰写一个指南
4指南评论
This guide was also useful to push back the pins of the headphone jack, as the plug got loose with the Gaming mic attachment.
Albert - 回复
Does that work for a lose 2.5 mm plug that it’s not making correct contact?
Marcos Ruiz -
Where can i buy the spare parts ?
Term - 回复
Where do we even get another receiver plug?
George “calfilmmaker” - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 22
过去 30 天: 97
总计 8,614
