跳转到主内容
Removal/Replacement of Dell Inspiron E1705 Hard Drive
你所需要的
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: 步骤 1 中的图像 1,1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: 步骤 2 中的图像 1,2 Removal/Replacement of Dell Inspiron E1705 Hard Drive: 步骤 2 中的图像 2,2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: 步骤 3 中的图像 1,2 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: 步骤 3 中的图像 2,2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: 步骤 4 中的图像 1,1
    • Slide the hard drive tray out of the hard drive compartment.
结论
3等其他人完成本指南。
Malik Shahbal
于10/05/10注册
471 声望
创作了5篇指南
团队
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G5
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 20,259
