简介
The diverter valve may become clogged if water is not rinsed regularly with water after foaming. Or if the seals are old and need to be replaced. Sometimes the mechanics are loose and the sliding mechanism does not close properly anymore.
你所需要的
After opening the lid, the machine shows its interior.
The water comes from the top right into the thermoblock and then enters the bottom right of the Themroblock in the switching valve.
Depending on the position of the milk frother nozzle, the water is either directed downwards into the frothing nozzle or to the left back into the thermoblock to the coffee spout.
Now, use the open-end wrench to free the diverter valve from all tubes and disconnect the hose.
Carefully disconnect the changeover valve from the milk froth nozzle.
If connections can not be easily solved, it is recommended to remove the complete unit consisting of thermoblock and diverter valve.
In the interior of the valve, a small plug is pushed to the left and to the right to close the outlet on the right when the milk frother nozzle is unfolded.
So no more water can get to the coffee spout.
Thoroughly clean the valve and check the seals and replace if necessary.
When reassembling, make sure that the milk frothing nozzle is fully inserted, that the sliding mechanism works smoothly and that the nozzle is firmly connected to the valve.
4等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
