跳转到主内容
修复你的物品
维修的权力
商店
在此拆机指南中使用的工具
简介
This guide will provide simple instructions for the removal of the outer casing of the TiVo Series 2. This may be necessary for interior part replacement or cleaning. The only tool needed for this tear-down is a T10 Torx or similar star bit screwdriver.
这个拆解是不是维修指南。 要维修你的的TiVo Series 2 TCD540080,请使用我们的维修手册
  1. Power down the TiVo and detach the power cable from the rear of the unit.
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. Remove the five T10 screws from the rear of the case using the Torx screwdriver.
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. Lift up and pull back the outer casing towards the rear of the unit. Lift up and pull back the outer casing towards the rear of the unit.
    • Lift up and pull back the outer casing towards the rear of the unit.
Svyatoslav Markeyev
于2010年04月16日注册
135 信誉积分
创作了5篇指南
团队
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G79
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 9
总计 4,291
