跳转到主内容
Remington S5500 Power Supply Cable Removal
你所需要的
  1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: 步骤 1 中的图像 1,2 Remington S5500 Power Supply Cable Removal, Power Supply Cable: 步骤 1 中的图像 2,2
    • Place the prying tool in between the hair straightener and the aligning cap.
    • Push forwards on the prying tool to pop off the aligning cap.
  2. Remington S5500 Power Supply Cable Removal: 步骤 2 中的图像 1,3 Remington S5500 Power Supply Cable Removal: 步骤 2 中的图像 2,3 Remington S5500 Power Supply Cable Removal: 步骤 2 中的图像 3,3
    • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
    • Use the prying tool to remove the aligning rods after the removal of the screws.
    • Gently separate each half of the hair straightener.
    • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
  3. Remington S5500 Power Supply Cable Removal: 步骤 3 中的图像 1,2 Remington S5500 Power Supply Cable Removal: 步骤 3 中的图像 2,2
    • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
    • Use the prying tool to remove the hinge cover.
  4. Remington S5500 Power Supply Cable Removal: 步骤 4 中的图像 1,2 Remington S5500 Power Supply Cable Removal: 步骤 4 中的图像 2,2
    • Pull upwards while pulling outwards to disconnect the wire from the housing.
结论
2等其他人完成本指南。
Benjamin Yohe
于07/11/18注册
303 声望
创作了2篇指南
团队
IUPUI, Team S3-G3, Wilson Summer 2018 IUPUI, Team S3-G3, Wilson Summer 2018 的会员
IUPUI-WILSON-SU18S3G3
5 名成员
创作了2篇指南
6条评论
Excelente trabajo! Muchas gracias por la información!
Ronnetto - 回复
is there a place where you can buy and replace the power cable, or the plug ?
alexandru popa - 回复
the slip ring plug that is ..
alexandru popa -
Hello,
from where did you get the spare power cord ?
Kes - 回复
part number would be helpful?
Steven Lamprell - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 57
总计 6,811
