本指南有最近更改,您可查看未经巡查的最新版本。
简介
Two tools required for the completion of this task include a PH1 screwdriver, and a prying tool.
All screws on this device are 10mm (0.393 in).
你所需要的
Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place.
Pull upwards and remove the black plastic cover.
Remove the ceramic plate by pulling the plate parallel to the straightener, while pulling upwards.
Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place. The screws are located in the same places as the other side.
Remove the two screws off of the chip using a Phillips #1 screwdriver.
Pull off the chip with the same method as the black plastic cover.
