跳转到主内容
Remington S5500 Ceramic Plate Removal
你所需要的
  1. Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: 步骤 1 中的图像 1,3 Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: 步骤 1 中的图像 2,3 Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: 步骤 1 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place.
    • Pull upwards and remove the black plastic cover.
    • Remove the ceramic plate by pulling the plate parallel to the straightener, while pulling upwards.
  2. Remington S5500 Ceramic Plate Removal: 步骤 2 中的图像 1,3 Remington S5500 Ceramic Plate Removal: 步骤 2 中的图像 2,3 Remington S5500 Ceramic Plate Removal: 步骤 2 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place. The screws are located in the same places as the other side.
    • Remove the two screws off of the chip using a Phillips #1 screwdriver.
    • Pull off the chip with the same method as the black plastic cover.
  3. Remington S5500 Ceramic Plate Removal: 步骤 3 中的图像 1,2 Remington S5500 Ceramic Plate Removal: 步骤 3 中的图像 2,2
结论
Benjamin Yohe
于07/11/18注册
303 声望
创作了2篇指南
团队
IUPUI, Team S3-G3, Wilson Summer 2018 IUPUI, Team S3-G3, Wilson Summer 2018 的会员
IUPUI-WILSON-SU18S3G3
5 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 40
总计 2,472
