跳转到主内容
Remington MB4040 Thermal Switch Replacement
你所需要的
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 步骤 1 中的图像 1,3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 步骤 1 中的图像 2,3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 步骤 1 中的图像 3,3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 步骤 2 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 步骤 2 中的图像 2,2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 1,3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 2,3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 3,3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 步骤 4 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 步骤 4 中的图像 2,2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 步骤 5 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 步骤 5 中的图像 2,2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 步骤 6 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 步骤 6 中的图像 2,2
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: 步骤 7 中的图像 1,1
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
结论
3等其他人完成本指南。
Cameron Carnahan
于01/20/15注册
1,067 声望
创作了6篇指南
团队
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,845
