跳转到主内容
Refrigerator Handle with No Drills Installation
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 步骤 1 中的图像 1,3 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 步骤 1 中的图像 2,3 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 步骤 1 中的图像 3,3
    • Use a clean sponge or damp lint free cloth to apply the handle to the surface.
    • Soapy water or other mild cleansers may be used to clean the surface from all grease or grime.
    • Preferably use cold or luke warm water.
  2. Refrigerator Handle with No Drills Installation: 步骤 2 中的图像 1,3 Refrigerator Handle with No Drills Installation: 步骤 2 中的图像 2,3 Refrigerator Handle with No Drills Installation: 步骤 2 中的图像 3,3
    • Gently clean the surface of refrigerator where handle will be applied.
    • Ensure the surface is completely dry before application.
  3. Refrigerator Handle with No Drills Installation: 步骤 3 中的图像 1,3 Refrigerator Handle with No Drills Installation: 步骤 3 中的图像 2,3 Refrigerator Handle with No Drills Installation: 步骤 3 中的图像 3,3
    • Clean the bottom of the handle's suction cups with a damp sponge or lint-free towel.
    • Ensure the surface is completely dry up before application.
  4. Refrigerator Handle with No Drills Installation: 步骤 4 中的图像 1,1
    • Once both surfaces are dry, place the handle with suction cups facing the refrigerator.
    • Position the handle on the side you would open the refrigerator.
  5. Refrigerator Handle with No Drills Installation: 步骤 5 中的图像 1,1
    • Position the handle vertically and at an appropriate height.
    • The height is up to your own personal preference.
  6. Refrigerator Handle with No Drills Installation: 步骤 6 中的图像 1,2 Refrigerator Handle with No Drills Installation: 步骤 6 中的图像 2,2
    • Apply pressure to both ends of the handle for approximately 15 seconds.
  7. Refrigerator Handle with No Drills Installation: 步骤 7 中的图像 1,3 Refrigerator Handle with No Drills Installation: 步骤 7 中的图像 2,3 Refrigerator Handle with No Drills Installation: 步骤 7 中的图像 3,3
    • Lock the suction cups in place by pushing down on the hatches.
    • Depending on manufacturer, locking the suction handles may differ in method.
  8. Refrigerator Handle with No Drills Installation: 步骤 8 中的图像 1,2 Refrigerator Handle with No Drills Installation: 步骤 8 中的图像 2,2
    • Slowly release the handle.
    • If handle detaches, repeat steps 4-8 until successful.
结论
Jaskaran Buttar
于09/29/15注册
125 声望
撰写一个指南
团队
Cal Poly, Team 10-7, Green Fall 2015 Cal Poly, Team 10-7, Green Fall 2015 的会员
CPSU-GREEN-F15S10G7
3 名成员
创作了3篇指南
一条评论
Help to fix a big hole where the door is holding on door falling off
Joya Hall - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 268
