跳转到主内容
Refresh, Reset, Start-up repair from USB recovery media
视频概述
  1. Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: 步骤 1 中的图像 1,3 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: 步骤 1 中的图像 2,3 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: 步骤 1 中的图像 3,3
    • - Make Surface turned off and plugged in.
    • - Insert the USB recovery drive into the USB port.
    • - Press and hold the Volume Down button, press the Power button in a short time.
    • - When the Surface logo appears, release the Volume button.
    • - Select the language and keyboard layout.
  2. Refresh, Reset, Start-up repair from USB recovery media: 步骤 2 中的图像 1,3 Refresh, Reset, Start-up repair from USB recovery media: 步骤 2 中的图像 2,3 Refresh, Reset, Start-up repair from USB recovery media: 步骤 2 中的图像 3,3
    • Now you are in the Advanced Startup Options menu. You can choose from:
    • - Refresh your PC
    • - Reset your PC
    • ...or from Advanced options menu:
    • - Start-up repair
    • - Command prompt
结论
8等其他人完成本指南。
ZFix
于12/09/13注册
191,882 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,516篇指南
3条评论
Hello.my surface rt is not working properly.The windows is on and off.What should i do?
Muzahar - 回复
Hello.My surface rt is not working properly.
The windows display is on and off. What should i do to prenvent it?
Muzahar - 回复
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
pigi01se - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 5,623
