跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
As this amplifier is almost 40 odd years old, the solder joints on the left bank, speaker wire terminal block, have cracked and now require the solder joints to be reflowed. This is a very common problem on old amplifiers.
  1. I used 1000v insulated electricians screwdrivers, as I like to be safe when working on electronics that have a higher risk of zapping me. Amplifiers can have a high current stored in the large internal capacitors. Even with the insulated screwdrivers, please be sensible and ensure the amplifier is unplugged and try to leave it without power for a day or so. Also, read up on working with capacitors before you start work.
    • I used 1000v insulated electricians screwdrivers, as I like to be safe when working on electronics that have a higher risk of zapping me.
    • Amplifiers can have a high current stored in the large internal capacitors. Even with the insulated screwdrivers, please be sensible and ensure the amplifier is unplugged and try to leave it without power for a day or so. Also, read up on working with capacitors before you start work.
  2. Turn the amplifier over onto its side and you will find two Phillips #2 screws holding the main black casing on, on each side of the amplifier. Remove them using the Phillips #2 screwdriver.
    • Turn the amplifier over onto its side and you will find two Phillips #2 screws holding the main black casing on, on each side of the amplifier. Remove them using the Phillips #2 screwdriver.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Once the main casing is removed, you'll need to remove the back panel. Keep the amplifier on its side and remove the two, Phillips #1 screws holding it on, on both sides of the amplifier. You'll also need to turn the amplifier over, and remove 5 additional, Phillips #1 screws from the back of the amplifier. Leave these screws in, as they aren't required to be removed, in order to take the back panel off.
    • Once the main casing is removed, you'll need to remove the back panel. Keep the amplifier on its side and remove the two, Phillips #1 screws holding it on, on both sides of the amplifier.
    • You'll also need to turn the amplifier over, and remove 5 additional, Phillips #1 screws from the back of the amplifier.
    • Leave these screws in, as they aren't required to be removed, in order to take the back panel off.
  5. Now, to completely remove the back panel and the left hand back service panel, you'll need to remove 5 Phillips #1 screws. To remove the service panel, you need to remove a further 3, Phillips #1 screws. once you have done this, you can remove the back panel and the service panel. Leave these three screw in as the service panel has larges holes for these three screws and undoing them, undoes the circuit boards stand offs.
    • Now, to completely remove the back panel and the left hand back service panel, you'll need to remove 5 Phillips #1 screws.
    • To remove the service panel, you need to remove a further 3, Phillips #1 screws. once you have done this, you can remove the back panel and the service panel.
    • Leave these three screw in as the service panel has larges holes for these three screws and undoing them, undoes the circuit boards stand offs.
  6. Now to get down to the reflowing. Put the tip of the soldering iron, onto each of the solder joins. When they melt (Aprox. 10 seconds using a 30 Watt soldering iron), add a little extra solder to the molten solder pool.
    • Now to get down to the reflowing. Put the tip of the soldering iron, onto each of the solder joins. When they melt (Aprox. 10 seconds using a 30 Watt soldering iron), add a little extra solder to the molten solder pool.
    • Once you have reflowed the solder joins, reassemble the amplifier and connect the speakers etc, to test if it has worked.
    • Don't hold the soldering iron on the circuit broad as you can damage it and the terminal block.
结论
5等其他人完成本指南。
zakk
于2013年11月29日注册
1,919 信誉积分
创作了2篇指南
团队
Master Techs Master Techs 的会员
Community
294 名成员
创作了943篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 25
总计 1,601
