简介
La cubierta de plástico sobre la antena en la parte inferior trasera del iPhone.
你所需要的
Inserta una herramienta de expulsión de la tarjeta SIM o un clip en el orificio junto a la toma de auriculares.
Presiona el clip para papel hasta que salte la bandeja de la tarjeta SIM.
YOU NEED TO PUT THE OPENER TOOL BETWEEN THE ANTENNA COVER AND THE DOCK CONNECTOR FIRST, THEN YOU WILL HAVE SPACE TO OPEN IT.. MY 2 CENTS
You better lay off the caps.
Very hard to remove and the plastic is very fragile
Take care when removing
When you get stuck follow this guy guide
Great Guide.
My dad banged his iPhone in a table after arguing with someone and got the aluminum cover next to the volume control bent in such a way as it got the volume control stuck in the max position. I used this guide to remove all parts out of the way so I can get the shape of that region and corrected it the "Han Solo" Way. It was an excellent opportunity to get the phone cleaned up as well
The biggest problem I had was screwing some of the screws back. The screwdriver that I had was not magnetized, so I used a little bit of superglue to bind the screw and the screwdriver until I had it screwed tightly.
The second biggest problem I had was that I lost a screw twice, but was lucky enough to find it quickly on the floor next to me.
I am very happy as I waited more than a month to get the confidence to get this iPhone repaired.
来自 Ivanfrost 的话:
how do i know what part is in my phone? There are 2...
Once you have the phone apart and have gently unplugged the power ribbon, read the part number on the ribbon. If it's in the 821- family, you can safely use corresponding 821 headphone assembly. If it is the other part number, use the newer replacement. Many sites list both parts and let you order the appropriately numbered part. Otherwise (if you order the wrong part) it won't work or you'll have to [unnecessarily] hack the part to get it to work.
来自 Steve 的话:
I bought the wrong one.... how do I hack it?
My iPhone is very first model. It doesn't have any of the four tabs shown.
The very first model does not have the four tabs. To open this version, use a plastic opener tool and push it into the middle of the tiny space between the rectangular dock connector and the antenna cover. Move the tool to the side and push it in a little deeper. A small gap should open up at the bottom of the antenna cover, where it meets the metal. Continue using the plastic opener tool in there, pushing it in and forcing it around the edge so that the antenna cover further separates. Then repeat this on the other side. To me it seems like a very brittle piece of plastic, so be careful. But now that it's loose at the bottom you can lift it with your fingers and work it off.
Inserte un spudger de metal en la ranura entre el conector de base y la cubierta de la antena. Haga palanca suavemente cerca de las dos pestañas para crear un pequeño espacio entre la cubierta de la antena y el marco frontal plateado.
Take heed to the note about getting the spudger between the dock connector and the cover. The dock connector is black plastic, as is the antenna cover, so it's difficult to see any gap between them. Putting the spudger between the metal shielding of the connector and the plastic is incorrect.
Inserta una herramienta de apertura de iPod en el espacio entre la cubierta de la antena y el marco frontal. La cuña de la herramienta debe apuntar hacia la cubierta de la antena. Deslice la herramienta alrededor de la esquina y hacia arriba hasta que llegue al soporte de metal.
Repita el mismo procedimiento en el otro lado del conector de la base.
Sujete la cubierta de la antena a cada lado y deslícela hacia arriba y lejos del iPhone. Esto requiere algo de fuerza. Si no sale libre, asegúrese de que la cubierta de la antena esté lo suficientemente levantada como para liberar las capturas.
It was released very hard on my iPhone 2G but the problem comes when i have to put it back.
It remains a little more space between the dock and the Antena cover and maybe that's because the two tabs between the mic and the speaker are not entered under the gold board?
If someone knows please tell me how to put it back.
Thanks
There is a very easy way to remove the cover by simply sticking duct tape on it and pulling the tape away of the phone.
It will leave no marks and it didn't damage my antenna cover as much(my "chinese" repair tools were to weak).
Thanks, using the tape was quick and easy, no damage at all.
Roeland -
Brilliant. Works perfectly. 20 seconds of work.
Para volver a armar su aparato, siga estas instrucciones en orden inverso.
108等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
3条评论
I need help I got my iPhone 2g 4gb pulled off the antenna cover and now it won’t go back on please help me!!!
This is very helpful
To remove the SIM, insert the end of a SIM eject tool or a small thin paper clip into the hole on the SIM tray. Press firmly and push the tool straight in until the tray pops out.
http://support.apple.com/kb/ht1438
neuronetix - 回复
I put the SIM card back in, and the slide to unlock does not work.
dean -
The only carrier to accept this iPhone was AT&T, they have discontinued use of that baseband. Nobody else in the world except for early renegade reverse engineers such as Geohot can get the device to work as a really old iPod no use unlocking the device because the technology inside the most recently OEM sold/refurbed iPhone 1st gen fails universally. You should only buy a screen assembly and snap it onto the back and call it a dummy phone and put it in a museum.
Alexander Weinhart - 回复
