简介
Quita la tapa de acceso para reemplazarla o acceder a el RAM.
你所需要的
Afloja los tres tornillos Phillips que sujetan la tapa de acceso al extremo inferior de tu iMac.
Quita la tapa de acceso de tu iMac.
即将完成!
Para reensamblar tu dispositivo, sigue las instrucciones en sentido contrario.
结论
24等其他人完成本指南。
由衷感谢以下译者:
en es
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
I am going to put a very important comment here. Before you start this process listen to the fans on your iMac do any of them sound obviously loud (think about how quiet your iMac used to sound as a reference) If you notice one or more of them sounding substantially loud compared to the others consider locating a replacement fan prior starting this process. After all if you are already “in the neighborhood” it is a shame to do all this work only to have to disassemble your imac a couple weeks later because you realize the fan is failing. I speak from my own personal learning experience of having to disassembly my iMac 3 weeks later because the HDD was failing and apparently the moving the fan around was just enough to push it to start really under performing.
Wizbang FL - 回复
I’m not sure why it is necessary to remove the RAM. As far as I can tell, it can remain in place during this procedure.
gordonhamachi - 回复
