跳转到主内容
Redragon K552 Key Switch Replacement
你所需要的
  1. Redragon K552 Key Switch Replacement, Key Switch: 步骤 1 中的图像 1,3 Redragon K552 Key Switch Replacement, Key Switch: 步骤 1 中的图像 2,3 Redragon K552 Key Switch Replacement, Key Switch: 步骤 1 中的图像 3,3
    • Unplug the keyboard from the computer.
    • Because this keyboard does not use a detachable cable, you will have to detach the cable from the PC directly.
    • The location of the cable depends on how you had installed the keyboard into the PC. (In my case, I have it installed on the rear of my PC next to my ethernet cable).
    • RGB lights indicate that power is running through the keyboard.
    • Make sure that no power is running through the keyboard during the replacement process.
  2. Redragon K552 Key Switch Replacement: 步骤 2 中的图像 1,3 Redragon K552 Key Switch Replacement: 步骤 2 中的图像 2,3 Redragon K552 Key Switch Replacement: 步骤 2 中的图像 3,3
    • Align the keycap puller to the keycap.
    • Use the keycap puller to pull out all the keycaps from the keyboard.
  3. Redragon K552 Key Switch Replacement: 步骤 3 中的图像 1,3 Redragon K552 Key Switch Replacement: 步骤 3 中的图像 2,3 Redragon K552 Key Switch Replacement: 步骤 3 中的图像 3,3
    • Dip cotton swabs into a bottle of rubbing alcohol solution.
    • Clean the keycaps using the cotton swabs.
  4. Redragon K552 Key Switch Replacement: 步骤 4 中的图像 1,3 Redragon K552 Key Switch Replacement: 步骤 4 中的图像 2,3 Redragon K552 Key Switch Replacement: 步骤 4 中的图像 3,3
    • Dip another cotton swab into the rubbing alcohol solution.
    • Carefully use the cotton swab to clean the surface and crevices of the keyboard.
    • Do not drop rubbing alcohol into the keyboard directly as it may cause damage to the keyboard.
  5. Redragon K552 Key Switch Replacement: 步骤 5 中的图像 1,3 Redragon K552 Key Switch Replacement: 步骤 5 中的图像 2,3 Redragon K552 Key Switch Replacement: 步骤 5 中的图像 3,3
    • Align the switch puller with the faulty key switch.
    • Pull the faulty key switch straight up from the keyboard.
  6. Redragon K552 Key Switch Replacement: 步骤 6 中的图像 1,3 Redragon K552 Key Switch Replacement: 步骤 6 中的图像 2,3 Redragon K552 Key Switch Replacement: 步骤 6 中的图像 3,3
    • Align the pins of the new switch to the keyboard.
    • Press the key switch on the keyboard until it clicks into place.
  7. Redragon K552 Key Switch Replacement: 步骤 7 中的图像 1,3 Redragon K552 Key Switch Replacement: 步骤 7 中的图像 2,3 Redragon K552 Key Switch Replacement: 步骤 7 中的图像 3,3
    • Replace all of the keycaps.
  8. Redragon K552 Key Switch Replacement: 步骤 8 中的图像 1,3 Redragon K552 Key Switch Replacement: 步骤 8 中的图像 2,3 Redragon K552 Key Switch Replacement: 步骤 8 中的图像 3,3
    • Plug the keyboard USB cable back to the PC.
    • Use a keyboard tester online to test your key switches.
终点
另外一个人完成了本指南。
Lyxander Blanco
于03/19/22注册
187 声望
撰写一个指南
团队
CSU Los Angeles, Team 6-2, Briggs Spring 2022 CSU Los Angeles, Team 6-2, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S6G2
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 47
总计 8,288
