跳转到主内容
Redmi Note 9 Pro - Reboots, Power On flex Replacement
你所需要的
视频概述
Xiaomi Redmi Note 9 Pro restarts - Power On flex replacement
  1. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: 步骤 1 中的图像 1,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: 步骤 1 中的图像 2,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: 步骤 1 中的图像 3,3
    • Warm up the device to soften the adhesive.
    • Use plastic tools and a little isopropyl alcohol to separate the back cover.
  2. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: 步骤 2 中的图像 1,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: 步骤 2 中的图像 2,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: 步骤 2 中的图像 3,3
    • Remove the Phillips screws that secure the motherboard cover.
    • Use a plastic opening tool to remove the cover.
  3. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: 步骤 3 中的图像 1,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: 步骤 3 中的图像 2,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: 步骤 3 中的图像 3,3
    • Lift up the flex connector to disconnect the battery.
    • Remove the main cameras.
    • Remove the SIM tray.
  4. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: 步骤 4 中的图像 1,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: 步骤 4 中的图像 2,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: 步骤 4 中的图像 3,3
    • Disconnect all flex cables:
    • Fingerprint sensor flex cable
    • Screen flex cable
    • Main flex cable
    • Coaxial antenna cable
    • Remove the Phillips screws securing the motherboard to the middle frame
    • Remove the motherboard.
  5. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: 步骤 5 中的图像 1,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: 步骤 5 中的图像 2,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: 步骤 5 中的图像 3,3
    • Remove the Fingerprint sensor.
    • Remove the volume buttons plastic cap.
    • Use isopropyl alcohol to help remove the glued down flex cable.
  6. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: 步骤 6 中的图像 1,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: 步骤 6 中的图像 2,3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: 步骤 6 中的图像 3,3
    • Use playing cards to remove the flex cable.
结论
7等其他人完成本指南。
ZFix
于12/09/13注册
195,943 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,452篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 31
过去 30 天: 140
总计 7,175
