跳转到主内容
RedOctane X-Plorer Whammy Bar Replacement
你所需要的
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: 步骤 1 中的图像 1,2 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: 步骤 2 中的图像 1,3 RedOctane X-Plorer Whammy Bar Replacement: 步骤 2 中的图像 2,3 RedOctane X-Plorer Whammy Bar Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: 步骤 3 中的图像 1,3 RedOctane X-Plorer Whammy Bar Replacement: 步骤 3 中的图像 2,3 RedOctane X-Plorer Whammy Bar Replacement: 步骤 3 中的图像 3,3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 步骤 4 中的图像 1,3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 步骤 4 中的图像 2,3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 步骤 4 中的图像 3,3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: 步骤 5 中的图像 1,1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: 步骤 6 中的图像 1,2 RedOctane X-Plorer Whammy Bar Replacement: 步骤 6 中的图像 2,2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: 步骤 7 中的图像 1,1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: 步骤 8 中的图像 1,1
    • Using two hands, remove the spring from the plastic tabs.
结论
3等其他人完成本指南。
[deleted]
于04/18/18注册
175 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 93
总计 3,555
